gas ????
gas ????
ok so the car has been sitting up for a little over a year and i put the car back together it has about a 1/4 of a tank of premium gas so my ? is should i just add more gas and put some fuel stabilizer in the car and crank it up or do i need to go in and drain the gas and start over?
Well, it is too late for the stabilizer, that goes in at the beginning, not the end.
If it were my car (and it is not) I would drain the fuel. I would put it into a car you don't care about as much, such as your DD, or even a mower if you have one. Then start with fresh fuel.
