Tested the Racetronix AEM Low imp injector box harness.
Coal Mining Director
Wanted to install an AEM low imp injector box since my Mototrons were maxed out with 84psi of fuel. Didn't want to splice my harness since I was not sure that I could tune the low imp 86lb injectors for the street.
Contacted Racetronix and they custom built a harness that requires zero splices .....just plug and play....AEM box and the 86ers tuned in great...been running it over a month now.
Racetronix harness quality is great.......could be a future product from Racetronix.
Originally Posted by JMBLOWNWS6
Will they make a harness for my versafueler? Id buy it now! Can you snap a pic?
Send Racetronix an email. As tight as the cowl/engine is....nothing will show in a pic now that it's installed.
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
Send us the wiring diagram for your VF via e-mail and we may consider making a compatible harness. Right now we have production scheduled for the AEM version first.
LS1TECH Sponsor
Originally Posted by Alex @ CMS
time frame on availability?
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Originally Posted by eb02z06
What about something for the FJO box Jack?
The AEM (10 channel) and Acceltronics (8 channel) driver box seem to be the most popular. Since the AEM's street price is $300.00 vs. $395.00 for the Acceleronics, we chose to put the AEM into production first.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
We could do something for the FJO but most people do not use it because it only handles 4 injectors so two boxes are needed.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
I will email you tomorrow. Can this harness be made and delivered to me by the 29th of this month?
__________________
>WEB SITE<
>WEB SITE<
You have the pictures now. Let me know. The only thing I would want different is my battery is relocated to the trunk so I would want extra lenght to tap the postive to the fuse box for a switched hot..
LS1TECH Sponsor
NEW Racetronix Impedance Converter Harness
Although this harness was measured for use in a LS1 car there are other applications which may fit. Please use the following lengths to determine if the RX-ICH will work for you.
battery connections to fuse holder / relay 12"
relay to driver box 28"
driver box to injector harness connections 40"
injector harness
cylinder A/B 22.0"
cylinder C/D 18.0"
cylinder E/F 13.5"
cylinder G/H 10.0"
This harness uses Minitimer injector connectors. These connectors are used on most high-performance injectors, aftermarket PCM harnesses and in many production vehicles dating from the mid 1980's up until just after Y2K.. The Minitimer connector is sometimes referred to as EV1 connectors.
At this time we are offering the RX-ICH harness for the AEM converter only. Harnesses for the FJO and Acceltronics converter boxes will be available very soon. Harnesses with longer lengths for remote location as well as 4 to 10 cylinder motors may be special ordered. Feel free to e-mail us with your custom application. Please note that on some vehicles it may be required to disable the factory PCM's injector circuit diagnostics. This is because the load exhibited on the PCM by the impedance converter box's inputs will not be the same as the factory injectors. Failure to make this change will not cause damage to the PCM but may set trouble codes.
Features:
shown with optional AEM 30-2710
click on image to view feature details
injector harness
cylinder A/B 22.0"
cylinder C/D 18.0"
cylinder E/F 13.5"
cylinder G/H 10.0"
Features:
- Fully plug and play with factory wiring
- Weatherproof factory-type sealed connectors
- Injector connectors embossed with the cylinder number for easy identification
- Direct battery power to injectors and converter box for maximum injector performance
- Dedicated independent fused circuit removes all injector load from factory wiring
- Factory ignition startup and shutdown
- Heavy-gauge power wires for maximum power to injectors
- Spare ATC fuse, wire ties, mounting hardware
- Lifetime limited warranty
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Our ad has been updated with info allowing customers to determine if this product may be used in alternative V8 applications.
__________________
>WEB SITE<
>WEB SITE<
