Is this too much? Inline MSD & Racetronix in-tank
Is this too much fuel for my application? My stock in-tanker has 120k on it and I think it is a little slow. I was going to replace that with the Racetronix in-tank unit, and replace my dying MSD in-line that I ran dry a few times with another one of the same units. I will have about 480 crank HP when im done with the motor. Also have 42lb injectors.
The racetronix intank pump will be plenty you are just adding extra heat to the fuel with an external pump. You are not going to pull anymore volume through the intank pump. And a single intank Racetronix is good for about 600rwhp.
Nate
Nate
