63 lb/hr Siemens High-Z Fuel Injector at 90+psi?
I need to run 90+ psi to get these to work with E85 is it possible? Or will that much pressure screw them up? I'd have to run a base pressure of over 70lbs and still make it idle.
With a Magnafuel 4301 pump.
http://www.magnafuel.com/products/efi/pumps/MP-4301.htm
The problem is height, with the Magnason Jackshaft unit I can't raise the fuel rail more than 1/4" on the drivers side without running into the bypass canister. This injectors are less that 2" tall
LS1TECH Sponsor
That is a bit too much pressure to be running the FI114962 injector reliably.
You should consider stepping up to 80's or better yet some low-z injectors with a driver module.
Unfortunately this is the highest flowing injector this size.
There may be an 80lb version of this injector but nothing in the immediate future.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I have run the taller siemens 60's at 73psi base pressure and 20psi boost on gasoline and never had any issues with it though I prefer to just run a larger injector.
Good to know, thanks. FICINJECTORS is helping me out with 80's.. And with my HP goal it should put me right at 80% at 75psi
