will bigger injectors make any problem
I'm putting 408 stroker for N/A used this year seeking for 500 rwhp but have a FI in my future plans next year or so
I'm thinking of purchasing 80 lbs injectors so i don't need to change them next year will they make any problem ?
Injectors seem to be most effecient around the 80% duty cycle. Those injectors will be way below that for your NA setup.
Also, if you're planning on FI down the road, I'm assuming that your 408 is going to be low compression. Not sure if you're going to see 500 rwhp very easy with a low compression NA motor.
its now 11.2 compression but i will change the heads to lower the compression to 9.5 next year
do you mean that the injectors with duty cycle of 50% will not be efficient the same as 80% injectors ?
