One Pump Ok?
One Pump Ok?
Ok guys..here is my setup. I am deciding wether or not a second pump will offer me any benefit at this point...
Its a stock long block 346 with exception of valve springs and push rods. Truck manifold build:
MP T70 .96ar
60lb Mototrons
Single Walbro 255
Does everyone think that I can properly feed that combo on one Walbro? Thanks...
MP T70 .96ar
60lb Mototrons
Single Walbro 255
How much power do you want and how much boost?
Right now I'm only getting about 7psi out of mine and I had to cut my second pump off to get my tune right. When I'm turn able to turn my boost up I will most likely need it.
I'm running a procharger, but i also ended up maxing the single pump out around the 550 mark.
I ended up with a dual intank set up, and followed the sticky in the fuel section. Best part is that its fairly inexpensive!
https://ls1tech.com/forums/fueling-i...ick-cheap.html
Probably not a bad idea to upgrade it now...
My $.02
--Mike
My $.02
--Mike
If you go over 550rwhp, plan on adding another pump.
When I turn up to 10psi on one pump, its not enough...
The twin in-tank modification is the way to go.
I believe Lonnie's Performance can set you up with one professionally done and warrantied for $600 shipped.
Or you can do it yourself.
Well I already have one, and a hotwire kit on it....
I dont plan to get past 500hp on this motor I dont think...I want to try and make it live if I can...
Does everyone wire in the second one to be on all the time, or on a hobbs switch to come on at a certain psi etc?...
Is it somehow more risky running just one? Or not really since two could lose power just the same? I will be running a Fuel PSI gauge and a wideband, so it will be monitored well
I was starting to lose a bit of fuel pressure on the single pump around 5psi, so i got it setup for 3psi to ensure i wont lose any fuel pressure.
I also have a toggle switch so i can turn on the 2nd pump manually if i want, but thats not really necessary.
Hope it helps...
--Mike
