Is Racetronix and Walbro fuel pumps the same pump?
LS1TECH Sponsor
Racetronix uses Walbro pumps in their kits, but they are modified for the specific application. Inlets are machined to the proper size, venturi lines added etc.
There are also many models of a 255 pump, many with the same 340 designation. Be aware all are not created equal.
Also the supporting equipment is of equal importance. Using the proper wire harness, instead of splicing connectors, using the proper fuel tubes instead of a rubber hose & other items to make it fit directly in your vehicle is what also makes the kits different. Do a seach on the various fuel pump problems & you will see how important the rest of the kit is.
These are the only brand of kit I sell for a reason.
