Renegade Race fuel?
Renegade Race fuel?
Anyone run Renegade fuel? Its ALOT cheaper than VP and Im wondering what the differences is between Renegades Pro116, C16 and Q16?
http://www.renegadepro1.com/index.ph...=110&Itemid=53
Race your car!
They used to be a big Torco distributor, that is where I thought they were linked, read the about us on the website.
It looks like they started doing their own fuel, which may, depending on alot of things, be a very close fuel to torco.
If you can get it for a reasonable proce, try it. Just be careful with the tuneup's initially, pull a few extra degrees and make sure you have a wideband on the car. The specific gravity of the fuels look good for what that's worth, if it was available in my area I would try it. The 118 Nos fuel looks like almost exactly the same spec's as Torco 118, probably behaves similar.
Race your car!
Not a bad idea.
I'd look at the specific gravity, and the lead content of the fuel, if the 2 are the same as torco is/was, you probably have the same thing again.
I wish I was closer to you I'd pick up a 5 gallon pail of the 118Nos and try it out when I get things going again.
