What length injectors do I need?
I am upgrading to LS3 heads and intake from LS6 heads and intake, but I plan on reusing my aftermarket fuel rail. Does the intake or the rail itself determine the injector height? Will LS1/LS6 stuff work on all intakes if you use LS1 mounting height rails?
I guess what my question is, is the factory LS1 and LS6 rail use the same injector hole to mounting flange height? Anyone have pics of each rail? I just need to know If I put my ls1 aftermarket rails on the ls3 intake, if itll need ls3 or ls1 length injectors
in order for you to lower the rail, youll need to get shorter injectors
All I have to do is shorten the blocks on the fuel rail mounting tabs and I should be good?
Also since I have a LS1/6 do I need a different harness to fit the LS3/7 injector electrically?
That is the point of my question. Once the injectors are purchased will they fit in my LS1 cathedral port intake as well as the aftermarket LS1 fuel rails (o-ring size specifically)?
The fuel rail ports should be the same diameter, and intake ports should be similar...I believe the LS3/7 are a fraction of a millimeter wider. The o-ring we use for the LS3/7 injector is a fraction thicker than the LS1/6 o-ring we supply.
The questions I have would be if the ports are spaced the same or close enough between the two head/IM designs and if there is enough adjustability in the way the fuel rails mount to make up for the 1" difference in height.
Well, just as I suspected. they did not fit.
The ls1 style injectors in the pic are too loose as previously stated. the ls3 intake has a little too much room for the o-rings. the height is off, but more importantly, the spacing for the mounting bolts is different. the frontmost mounting biolt on the ls3 intake is moved forward from the ls1/ls6 style
this stuff is never easy
