Reinstalling bucket w/o pump, installing inline but want tank level sender function.
Is there anything I need to do when reinstalling the bucket w/o the pump? Is it ok to leave the connector just hanging in there or should I terminate the ends with plugs?
All I want is the sender function to work.....
Thanks!
FWIW I have HPT I suppose I could just shut off power to the pump wiring?
Thanks!
Thanks...
I have a Racetronix hot wire harness, which Im using to power the external pump.... which I believe taps into the pump wiring to feed the Racetronix relay... I wonder if pulling the front OEM relay will interupt feeding the Racetronix relay.
