Post up Pics of your fuel line routing!
I am looking to see how some of you have routed your fuel line's when on a gen4 fbody.. i am running Naty Nate's fuel cell with the magnafuel 4303 pro tuner 750 pump submerged in the tank with -10 feed & -10 return.. mainly wanting to see how you came into the engine bay, i am running the lines before i drop the motor in so i can secure them easier without the motor in the way.. So far i am coming up just like factory but am going around the steering shaft then from that point i am either going to loop around the backside of the brake booster and over the top of it to a Y-Block into the back of the rails or i am going to go around the backside of the steering shaft and up between it and the brake booster.. Just curious as to how some of you have done it and if u have pics that would be great as well! I will post pics of fuel line routing from back to the front and pics of the the cell momentarily which by the way is a piece of art
The Nasty fuel tank, Submerged Magnafuel Pro tuner 750...
Outlet and return with Sending unit connections and Fuel pump power bulkheads..
Fuel line Clamps in factory location..
-Rear of tunnel
-Front of tunnel
-Under driver floor pan to engine bay
About to take pics of the feed routed in the clamps and to the filter..
-Rear of tunnel
-Front of tunnel
