how to tell if i have a bad or leaking injector??
my car is fouling the number 5 spark plug out. It was leading me to believe i had a bad valve seal or guide but i have taken the head off and set it to the machine shop and it all checked out ok. the reason i thought it was that cause i thought it was oil but i am leaning towards that its fuel. The combustion chamber on that cylinder is sut black along with both valves. The car dont smoke on start up but it does if u rev hard or stab the gas while driving it will smoke. I pulled the head off and their is a small amount of build up on both intake and exhaust valves on the number 5 cylinder. Any help or suggestions would be greatly apreciated..
Try ohm testing the injectors, both hot and cold, then post up the readings.
http://www.youtube.com/watch?v=_g8PdrT0MCU
