60# Injectors for 600whp NA?
I'm currently building an LS7 stroker setup looking to make around 600whp on motor before a wet shot. I'm running a full return system with twin walbros in my Nissan. Will 60# injectors work at this power level? It would be nice not to have to scale my tune.
FWIW, the LS3 Camaro Whipple kit comes with 63# injectors and most of those, mine included, make around 600 rwhp without much difficulty at all. I'm guessing you'll be fine but, I'm no expert.
if you are doing a naturally aspirated setup and wet nitrous you shouldn't have a problem at all.
www.rceng.com and go to the technical sizing link on the left side navigation. You will be fine.
My 60lb injectors were almost maxxed out (90% duty cycle) running at stock fuel pressures at 600rwhp. Then again we were tuning rich and it is a procharged setup. You will be fine.
42 lb ls2 injectors did the deed for 500rwhp na
I would look at 56lb zr1 injectors
Plug and play injector data
And a done deal no scaling either
If you are spraying they might not do the job.
The only 60lb injector I'd be looking at is the deka 60's
They are a 72-73lb @ 4 bar
So they require scaling
