Question on Fuel Pressure
Right now I am building a turbo motor, I was wondering, would there be any great detriment to running my starting rail pressure at around say 60ish PSi an use a boost referenced regulator?? I have a Lonnies Perofrmance Double Pumper and will be runnign 8An lines (stepped up from the sending unit outlet) up to a set of rails run in parallel to a magnafuel regulator to a 6AN return back to the tank. Any info would be helpful, thanks.
What power level are you trying for?
What size engine?
How much boost?
Personally, 60psi as a base setting sounds a little high to me...unless you're trying to use stock injectors and low boost.
Engine is a 383 Lt1. Power level, well, shooting for the moon on this one, the turbo I'm using is capable of 1400hp, im aiming for like 1000-1100. The injectors are 83 lb/hr units. and boost is in the 16-22psi range. I was talking with my builder and tuner and they were saying I can run 60 if I want but might be better off going with the 83s at more like 50ish and then swapping to larger like 95s or bigger later since I'm using a FAST XFI and can handle using low impedence injectors, but, we can iron all that our later, I jsut wasn't sure if people here had any input or experience.
LS1TECH Sponsor
You need a bigger injector instead of high pressure. Remember you are trying to boost reference 60psi plus 22# boost. Not the way to do it.
Get a big injector & run low pressure (43# base), the pumps will handle way more power this way. You will max out at 65psi fuel pressure boost referenced. An 80# injector rated at 3 bar should be good for your application up to about 900rwhp.
Not sure how your FAST injectors are rated... thay have a habit of rating many of them at 4 bar to confuse everyone.
