HELP: car wont fire/start
just installed a new racetronix fuel pump. wired everything up fine. it fired up a few times in the drive way. when i took it out for a test drive i blipped the throttle and then the car just stalled? i turned the key to start the motor again but it wont. fuel pump primes but theres no fuel at the rail. checked all fuses and they're okay. i tried starting it about ten times but it drained the battery(voltage at or just below 10v) and now i gotta jump start it and get some juice to the battery
any ideas? im going to pull the fuel pump and check if anything's wrong with it
edit-this is what i replaced before installing the pump-fpr and fuel filter
