anyone have 80lb siemens dekas?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Tuner said they will cause issues on my motor since I am running n/a until I break my motor in. i.e. bucking, drivability, and idle issues. anyone running 80lb dekas that are n/a that can confirm this?
the motor is a 370ci lq9, turbo cam, 8.5:1 compression, ls6 intake, nasty fuel rails, aem fpr, stock feed -6 return.
I figure if the injectors cant control that low of a pw i could turn the fp down and solve the problem.
i have a set of siemen dekas i ran in my turbo 99 t/a, and i could not get it to idle for ****..so i took them out and reflashed the pcm for the stockers..idk if maybe the inj flow rates were off or what, kinda put that on the back burner until i get the rest of the motor dialed in and set where i want it..now im at the point they need to be installed..is this just a matter of changing the IFR'S?
