How to setup a fuel pump relay??
Old 03-12-2012, 05:12 PM
bmf5150's Avatar
Default How to setup a fuel pump relay??
Any good Web sites or info out there on how to setup a fuel pump real for a aero motive 11140 style pump!not sure how to wire the relay!thanks guys
Old 03-12-2012, 05:14 PM
bmf5150's Avatar
I'm running a ls6 in a 68 camaro fuel injected ,going to add on a kenne bell do I'm going to need more fuel!stock wiring won't handle the job!i currently have a ricks hot rod gas tank
Old 03-12-2012, 07:00 PM
JaYZeig's Avatar
i just wired a second fuel pump for my trans am this weekend actually...this is a good basic diagram to go off of to give you and idea on where each wire needs to go...
and for terminal 86, i personally used a hobbs switch to turn my pump on when i hit 2 psi boost...i dont know the situation you have for a signal wire...but im sure you can use your signal wire from your pcm to turn your relay on, so itll power your pump.
Old 03-12-2012, 07:51 PM
bmf5150's Avatar
Awesome,exactly what im looking for!
Old 03-12-2012, 07:52 PM
bmf5150's Avatar
What kind of relay would that be considered??spdt??
Old 03-12-2012, 09:46 PM
JaYZeig's Avatar
actually im not sure what relay that is..however, i used a relay that just had 4 prongs on it...im sure if you got a 5 prong one though you just wouldnt use that extra 87 thats on it.
Old 03-12-2012, 11:33 PM
ChuckD's Avatar
I just wired an Aeromotive pump in my Buick Sunday. Just like the diagram above. I left the center one alone. Works like a champ.
Old 03-13-2012, 12:59 AM
bmf5150's Avatar
Ok thanks guys!!
Old 03-15-2012, 03:04 PM
bmf5150's Avatar
One last question guys,what size wire u guys using??
Old 09-27-2012, 02:23 PM
LSX FOX's Avatar
10gauge for the pump neg.
10gauge for the pump pos.(to relay pin 87) through the relay and then 10gauge to the alternator charge stud (from relay pin 30)
the relay ground can be 16 or 18gauge(relay pin 85) and so can the fuel pump power wire(relay pin 86)
the 10gauge is highly recommended for the right amount of current draw for the pump to perform best.
Old 03-24-2013, 08:57 PM
Killer66's Avatar
Default fuel pump
Out standing, just what i needed.
Quick Reply: How to setup a fuel pump relay??
