other pump options
Old 03-22-2012, 12:02 PM
jlaudioholic's Avatar
Default other pump options
I recently swapped an LS1 into my '97 LT1 T/A. During the swap I swapped the stock LT1 fuel pump for a LT1 Racetronix pump and hotwire kit. I got the swap running last week. I took the car out on its first post swap drive yesterday and after about 10 miles the car died on me after I took a turn. I could not immediately get it started, I waited a few minutes and got it going again. I decided to head back home and on the way back the same thing happened several more times, until I was a block away from my house and it completely gave up on me. I can no longer hear the pump priming and I have confirmed that I still have power to it.
When I installed the pump I completely drained the tank of old fuel, and note that the tank was very clean. Now my question is this, should I risk buying another racetronix/walboro pump or is there any other options out there? I would hate to keep throwing $150 out the window with no warranty everytime it goes out.
Old 03-22-2012, 12:56 PM
ICRAZY6's Avatar
Is the fuel pressure the same on an LT1 as an LS1?
Old 03-22-2012, 02:38 PM
No the LT1 is around 45psi and the LS1 is 58psi if I remember right. Im using a corvette filter/regulator also, as are many others that have done this swap.
Old 03-23-2012, 07:46 AM
ICRAZY6's Avatar
Could the fact that he's running an LT1 fuel pump to supply and LS1 motor be his problem? Not enought fuel???
Old 03-23-2012, 03:54 PM
RX-Matt's Avatar
No the pump is a 255lph and will surely meet his demands.
Have you posted on our www.racetronix.info forum?
It is VERY rare for a pump to die like that, especially given that you seem to have installed it correctly. Typically early failures are due to installation error.
Old 05-05-2012, 08:48 AM
dirty94SS's Avatar
Yeah I'm going through the same issue when I still have the stock pump 94 impala ls1 swap a wot car felt like it cut off then I got a half block home too the car just shutoff... I'm about to go and get a racex
Old 05-06-2012, 07:24 AM
Old Geezer's Avatar
Tank vented??
Old 05-07-2012, 11:47 AM
Nasty N8's Avatar
Old Geezer has the right question. Sounds like the vent. The Walbro used in the Racetronix are some of the most reliable pumps available.
