Are EV1 Delphi style lowz injectors a drop in install?
Old 07-25-2012, 08:53 AM
Forcefed86's Avatar
Default Are EV1 Delphi style lowz injectors a drop in install?
Running a 98 ls1 manifold and fuel rail. Picked up a set of 96lb delphi injectors and an AEM injector box. Will these injectors drop right in? Or do they need to be modified in any way to work? I held them up next to a factory injector and they seem slightly taller. Although It looks like they would be close. My manifold is out right now Or I'd just check.
thanks!
These injectors if it helps...
http://www.diyautotune.com/catalog/d...owz-p-280.html
Old 08-19-2012, 05:18 AM
stevieturbo's Avatar
They should just drop in, with associated wiring of course. Depending on rails used, there may be some clearance issues due to the fat body though
