Need help with finding pin-out for #1 injector.
Old 07-27-2012, 02:41 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default Need help with finding pin-out for #1 injector.
I'm hooking up my Aquamist meoh/water injection and it runs on injector duty cycle, so I need to tap the signal and ground wire for the #1 injector. I'd prefer to do it at the pcm, so does anyone have a chart or location guide to the pin-outs for the PCM in a 2000 f-body?
I'd hate to have to undo all of the wiring harnesses to trace it back.
Thanks.
Old 07-27-2012, 03:13 PM
UNDER PRESSURE MOD
Ok, thanks to this link:
http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm
I know that it's #36 on the blue harness for the signal wire, but what about the second wire coming off the injector harness, does that go back to a common ground?
Old 07-29-2012, 09:02 AM
bayer-z28's Avatar
See if this helps.
http://cs.chevroletclub.net/graphics...g.diagrams.pdf
Old 07-29-2012, 03:55 PM
LS1MCSS's Avatar
Here ya go.
Attached Thumbnails Need help with finding pin-out for #1 injector.-fuel-injectors.gif
Old 07-29-2012, 03:56 PM
LS1MCSS's Avatar
It goes to a 15A switched power fuse.
Old 08-19-2012, 05:16 AM
stevieturbo's Avatar
Injectors on all cars receive an ignition based 12v supply. The each injector has a ground trigger to open/close the injector as required.
It is this wire you need for the controller.
Old 08-19-2012, 05:40 AM
UNDER PRESSURE MOD
Thanks for the replies guys. I got it figured out. Hopefully I'll have the system live in the next few days once things around here calm down.
