Time for Injector ^grade?
Old 08-22-2012, 11:44 PM
DisasterpeaceWS6's Avatar
Default Time for Injector ^grade?
Installing new cam and heads tomorrow and curious if I need to upgrade the injectors as well.
Old 08-23-2012, 10:33 AM
ZL1Killa's Avatar
i would advise it, stock injectors don't last long. chances are after those long tube headers your injectors were above the 80% threshold.
for your setup I would advise an injector in the 32# @ 43.5psi to 36#@ 43.5psi, and as our rail pressures are 58psi you would need to adjust the tune accordingly as you got more flow with more pressure (not linear).
talk to FIC on here. Also FYI, the stock fuel pump, 190 liter per hour, maxes out at 38# injectors. That being said, if you ever go for some big power, I suggest getting the Racetronix/Walbro 255 PnP kit from Racetronix, Lonnies, or NastyN8
Old 08-24-2012, 03:07 PM
I just found out yesterday while breaking down my engine for the cam install that the stock injectors do not fit my new fuel rails. Thinking bout going with some LS2 injectors. Any thoughts on LS2 injectors? I know they are rated for 34.9 pph
Old 08-24-2012, 05:15 PM
I don't really plan on going anywhere over like 650+ rwhp I just need some injectors that will fit the FAST 102 with this LS2 fuel rail I got.
Old 08-25-2012, 09:07 PM
ZL1Killa's Avatar
well i tell ya this, its an entire different ball game going from your heads and cam to 650rwhp... you will need another upgrade for that.
for what you are doing now those would work
Old 08-26-2012, 02:41 AM
Cool. Good to know cause I already paid for them and they are in the mail hah. Thanks
Quick Reply: Time for Injector ^grade?
