LQ4 injector recomendation
Old 10-01-2012, 02:35 PM
Nova 404's Avatar
Default LQ4 injector recomendation
I have an LQ4 with a TSP 228R cam and the FAST LSXRT intake and 102mm TB in an older muscle car.I am using the 243 heads for a bump in compression.I will have 1 3/4 long tube headers.In searching I see the stock injectors are likely to small to be efficient.Harness ends not critical as I have not bought a harness yet. What is the flow rate that would be required for 400-450 hp.I do also have the FAST rails so I assume I have some choices on injectors.i have heard the 8.1 injector is a inexpencive upgrade.
Old 10-05-2012, 07:52 PM
ACHTUNG's Avatar
I'd like to know this as well.
Old 10-06-2012, 07:10 AM
Old Geezer's Avatar
https://ls1tech.com/forums/fueling-i...ump-chart.html
Old 10-07-2012, 10:29 PM
Nova 404's Avatar
Does anybody know if all 8.1 njectors are the same?Are there any more desiable than others? I see different part numbers offered or sale
Old 10-08-2012, 10:31 AM
FICINJECTORS's Avatar
there are two 8.1 the marine injector and the truck injector. the trucks are 36@58psi and the marine are 42@58.. both identical bodies and plugs
Quick Reply: LQ4 injector recomendation
