Nylon corrugated fuel hose install help
I ordered a few pieces of nylon corrugated hose to connect 2 walbros to barb fittings, but I am not having any luck installing it. I have tried boiling water w/ a little oil, but couldn't even get it past the first barb. I need the flexibility of the corrugated hose, so I don't think submersible rubber hose will work.
Any suggestions welcome
My way...
We use a heat gun to warm it up.
A trik old folks use, is to put the fitting in the alum vise jaws, facing away from you. Put a pad on the close side of the vise,[keeps body damage to a minimum!].
Warm the hose and then pull it on. Tig welding gloves are my choice.
We use crimp clamps on the connections.
We use Fragola hose, fittings, clamps.
