Symptoms of a bad fuel pump please help
Old 02-04-2013, 09:48 PM
98 ls1 jimbo's Avatar
Smile Symptoms of a bad fuel pump please help
I have a 98 ls1 camaro just hit 100k the car won't start right away it will take about 4-5 seconds to start. Is it the fuel pump it been doing this for about one month. If I run it and stop it will turn back on right away but if I let it get cold it will lag to turn on. What can it be. Already changed my fuel filter
Old 02-05-2013, 08:30 AM
bmcfadin85's Avatar
Have you tested you fuel pressure? I've been having fuel issue's on both my 98's lately.
Old 02-05-2013, 11:03 AM
torkls1's Avatar
I have the same problem. Sounds like a check valve issue which causes a loss of fuel pressure when the vehicle is not running. Here is a link to my thread from quite some time ago: https://ls1tech.com/forums/fueling-i...ump-issue.html
Old 02-15-2013, 04:05 PM
mrhtl's Avatar
when my fuel pump went it literally just went, the car did not start. I drove it to work just fine. went to go to lunch and no more fuel pump. so there could be a different culprit in your case.
Old 03-15-2013, 12:52 AM
I did its at 60 psi. I think it might be the fuel Pressure regulator. It's not holding the pressure. It's on the Fuel rails I think
Quick Reply: Symptoms of a bad fuel pump please help
