Are there any issues running "T" fitting instead of Y fuel block?
I would prefer to use a T fitting, it would be a cleaner look and already a small space to fit a Y block.
putting a T fitting where stock and Aux fuel pump meet to go into a single fuel line, then again a T fitting where main line meets fuel rail.
Any issues with doing that?
What are the advantages of a Y block here, smoother flow? etc..
I've seen vendors using a T fittings that connect an aux pump between a quick connect, so essentially doing the same thing, but wanted to confirm.
thanks so much.
thanks so much.
