opinions on return setup
Old 06-20-2013, 11:11 PM
Mrmooney's Avatar
Default opinions on return setup
Due to my alternator location I have to run cross over in rear is there any issues with either diagram below I made in paint lol. Haven't stared doing anything yet other then buying pieces. Any help would be great. Car is 99 ta with l33 5.3 turbo cam ls6 intake 799s 76mm Precesion 7675 turbo 400 Ford 9inch running E85 with 2 fic 340s. Hoping to make around 750-800.
Using stock feed as return new -8an as feed.
Old 06-22-2013, 07:46 AM
Mrmooney's Avatar
90 views and no response?
Hoping to get this done this weekend.
Old 06-22-2013, 09:36 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
There is essentially no difference in your 2 choices, both will work the same. Just use -8 for the feed into both.
They will work, but the design is not ideal.
Personally I would bet I could come up with something to allow a return from both rails.
Some tight -6 90's will likely fit on the rail outlet. You only need about 1.5".
Old 06-22-2013, 09:41 AM
Mrmooney's Avatar
I have only have maybe 1/2" from stock rails to back of alternator. Ill be running aftermarket rails. I didn't know if it mattered which side fed rails. If plug side mattered.
Old 06-22-2013, 09:02 PM
Mrmooney's Avatar
Also I'm trying to avoid using 90s if at all possible.
Old 06-23-2013, 08:40 PM
x275radial's Avatar
that design is no good. you should never have one rail dead headed
Old 06-23-2013, 09:02 PM
Mrmooney's Avatar
Dont have a choice due to alternator location.
Old 06-24-2013, 04:29 PM
Mrmooney's Avatar
Here is the rail with injectors in it and how much room there isn't lol. So guess my question now is the above diagram with that side plugged is that better then just running the stock rails?
Old 06-25-2013, 12:16 AM
8 Second Truck Club
Blown06's Avatar
just take that plastic cover off the alternator, clearance it, and reinstall. I've had to do that before. A tight 90 will then fit.
Old 06-25-2013, 02:32 PM
Mrmooney's Avatar
Sweet will check that out.
Old 06-25-2013, 05:36 PM
Ollie8974's Avatar
You may have to use a 90 whether you want to or not.
Quick Reply: opinions on return setup
