e85 aem pump plus 80 lb injectors meat my goal?
Old 12-03-2013, 11:48 AM
sixt5's Avatar
Default e85 aem pump plus 80 lb injectors meat my goal?
engine should be upper 600 horse if my research is correct. money is getting tight though which is why the aem pump.
80lb big enough?
also i have 20+ feet of 3/8 aluminized steel fuel line. would this be an issue with e85?
thanks ahead of time!
Old 12-03-2013, 07:08 PM
Blackpanther99's Avatar
Youll be good overall IMO
Old 12-11-2013, 08:37 AM
2muchboostNY's Avatar
My buddy did most of the research on this project...if you want to play it safe go Teflon or PTFE lines or coated:
http://iqlearningsystems.com/ethanol...patibility.pdf
Quick Reply: e85 aem pump plus 80 lb injectors meat my goal?
