LQ9 starts but wont idle
Stock injectors...tried.swapping intake, throttle body, maf, and tac module.
Electric throttle body and has throw lean code, and just tonight threw a crank position code. Motor is a swap that has never run for me yet. First time is started motor I had the brake booster unhooked, so thought maybe computer is trying to compensate by closing throttle body tight???
Thats the confusing part.... if i put my foot on the gas pedal, I can get it to run and rev up....runs like crap mind you
I have started it a bunch of times since it threw the crank code.... nothing, no more codes.... and most of the time i do have codes... the check engine light is not on?
