My truck harness has 2 different types of injector plugs...
I'm a bit confused here... I've got a truck harness with red/blue pcm connectors from a 2002 truck I believe, and it has 6 EV6 plugs and 2 EV1 plugs. I got the harness from a member here, and it was all stock and still wrapped in the factory loom and tape. No cut/splice jobs anywhere in the harness (I took the it apart myself and it was all stock). I'm mocking everything up on an engine stand, and realized that the injector plugs are different. All cylinders except 5 and 7 have EV6 plugs on the harness, and 5 and 7 have EV1 plugs. I have a spare harness with all EV1 plugs, but I've got a lot of time invested into this one converting it into a stand-alone. I guess I will pull the injector harnesses off my other harness at the computer end and pin them into this one. Has anyone seen this before or can explain it? Maybe it was a changeover year or something? The motor it came off of must have either had mismatched injectors or adapters on some of the injectors.
