Injectors are 39lb...tune is set for 37lb..
So, I just figured out that my tune has the injector flow set for 37lb...and my injectors...the white top bosch type, #0280155737, flow 39lb at 58psi. The car runs pretty well, although a little lean in a closed loop idle. I have efi live, should I go ahead and set the calibration for 39lbs?
Thanks.
Thanks.
