E-85
Old 08-22-2014, 04:21 AM
Mista Blazer's Avatar
Default E-85
Going to be picking some brains for this. Other then cam and ls6 intake I'm fairly stock in the motor area, but with current gas prices I wouldn't mind swapping to E-85. But to do this will I need to get rid of the steel tank from my 98'. Was reading through this.. https://ls1tech.com/forums/showthread.php?t=602091&styleid=27
Old 08-22-2014, 11:08 AM
maroonls1z's Avatar
So what exactly are you asking?
Old 08-22-2014, 06:55 PM
What is needing to be upgraded to run E85
Old 08-22-2014, 07:32 PM
maroonls1z's Avatar
New pump and injectors that are e85 compatible and id replace the rubber section that goes from the hard line to the rail with something that is ptfe coated
Old 08-23-2014, 09:31 AM
So I won't have any issues using my factory steel tank?
Old 08-23-2014, 11:05 AM
maroonls1z's Avatar
Sorry, you had said you were already going to replace that. E85 attracts water which causes rust. I think the steel fuel lines are alright but I would probably swap in a newer take since you have to pull it to replace the pump anyways
Old 08-24-2014, 04:12 AM
No I was asking in the OP if I needed to replace it
Old 08-25-2014, 06:03 PM
LOLH4's Avatar
I would seriously consider replacing it due to the humidity in your area and the effects of e85 on non stainless.
Quick Reply: E-85
