P0171 and p0174
Old 09-09-2014, 12:16 PM
Ls1dirtybird's Avatar
Default P0171 and p0174
Hello I have a 98 ls1 trans am. Codes p0171 and p0174 are popping up on the obd2 scanner. Does kind of idle a little rough, but sometimes my engine lights turns off and then later comes back on. Codes say bank 1 and 2 are running lean. Could this be a vacuum leak?
Any thoughts? Thanks
Old 09-14-2014, 11:37 PM
Mercier's Avatar
Too much air, not enough fuel, or the O2 sensors are lying. So vacuum leaks, fuel filter/regulator/pump/injectors, or O2 sensors or wiring. Possible the MAF is dirty and thinks less air is entering the intake than actually is..clean it with MAF or electronics cleaner. Also IAC could be open when it is not supposed to. That will let in more air.
Quick Reply: P0171 and p0174
