Need help with fuel routing
Noob when it comes to fuel systems im using stock fuel tank/pump from a 00 fbody and a ls6 fuel rail.
Two questions is this diagram correct for the returnless style system and second I plan on using russel fittings and -an line what size do i need to use on the feed and return
644123 on the inlet side, and the outlet is an M16x1.5 o-ring fitting iirc. If you don't have that stuff for the tee fitting I would get a different filter. A 33484 filter has 3/8 push connects on both ends so you could just use generic fittings for the tee and line back up to the return on the pump.
probably sounds stupid but how do the 644123's go on and it seems like the 640853's would be better?
http://www.russellperformance.com/mc...injected.shtml
