Return line using evap?
Old 02-27-2015, 01:15 AM
transamfreak01's Avatar
Default Return line using evap?
My set up is a 408 with a single 91mm turbo should put down about 850rwhp and might take it up a little more.
A local shop told me they run 6an there and use the evap back. My original plan was to run a 8an there and 6an back. What do you guys think about this? Not sure how I feel about the evap running back
Old 02-27-2015, 02:20 PM
Anyone? Going to do this, this weekend so looking for insight before I start
Old 02-27-2015, 02:31 PM
94LS1B4C's Avatar
The most common answer you will hear is to run -8an for feed and use the original feed line as the return. This is how I will be running mine.
-6an for feed will be a restriction for your application IMO.
Old 02-27-2015, 03:35 PM
That's what I figured but they said they use a 6 feed on all their 1000hp cars. So I'll just do the 8 as a feed.
Another question, I've been told nylon, Teflon, and the plain steel braided. What do you guys recommend? Bc I was looking at the psi rating for the nylon and it didn't seem like it was enough
Old 02-27-2015, 05:35 PM
94LS1B4C's Avatar
It's pretty much personal preference between nylon and steel braided. Teflon is used for brake, power steering, nitrous applications.
Steel braided for the cheapest solution. I'm going with the nylon hose because it's easier to work with as far as putting the fittings on. It's lighter too for whatever that's worth. Some also say the nylon dissipates heat better than the steel braided.
Old 02-27-2015, 08:02 PM
Ok awesome thanks. I was trying to search for a write up but didn't find one on what fittings/adapters I would need to use the stock feed as the return.... Any ideas?
Old 02-27-2015, 11:57 PM
94LS1B4C's Avatar
http://www.jegs.com/i/Russell/799/64...rentProductId=
And look through this thread for back at the pump ideas. This is similar to how I will be doing mine.
https://ls1tech.com/forums/fueling-i...-tutorial.html
Old 02-28-2015, 09:15 AM
Thanks!!!
Old 02-28-2015, 05:35 PM
Realcanuk's Avatar
Not sure where this info is coming from. PTFE fuel line, which is Teflon, is by far the best thing to use. Normal braided line does not hold up well to modern fuels and fuel smell comes through it.
Old 03-01-2015, 01:53 PM
94LS1B4C's Avatar
http://www.russellperformance.com/mc...oclassic.shtml
http://www.russellperformance.com/mc/hose/proflex.shtml
Old 03-01-2015, 01:57 PM
94LS1B4C's Avatar
I assume your going off of this?
http://www.anfittingsdirect.com/ptfe...fe_teflon.html
The OP didn't state that he is even running E85.
Old 03-01-2015, 02:13 PM
Realcanuk's Avatar
Been running E85 for years with Russell line with no problems.
I am not going off that. Never seen it. I am going from my experience and others. PTFE hose guarantees you wont get any gas smell. I just went through this an would not use anything else. Not saying the russel isn't good.. I have it all over my car... just not for fuel.
I just had to redo my fuel pump lines because my garage smelled like a gas station.
To each their own. I am just passing on my experience.
I use Russel for coolers...
As well as catch can hoses and other stuff... its nice hose.
Old 03-01-2015, 10:05 PM
I'll take a look through those links. But I am NOT using e85. We don't have it for like 30 miles and I'm not going keep drums of it in my garage. I'm just looking for good fuel line that doesn't cost a fortune and is easy to work with. A local shop wanted $150 for 8an feed and I'm sure there was a little up charge on that
Old 03-02-2015, 08:03 AM
I found a few hoses on the bay. They wanted like $110 for the black nylon on 20 ft for 8an. Is 750 Max psi enough? I would figure yes but the steel braided is double that. If not where's some decent prices ? Sponsors?
Quick Reply: Return line using evap?
