backwards gauge
Old 05-21-2015, 01:30 AM
cchvyd28's Avatar
Default backwards gauge
I have a 98 trans am and the fuel gauge reads backwards. I was told by the previous owner that when he switched fuel pumps, he used a sending unit out of a 99. Works fine, just backwards.
Everything I have read about backwards gauges people have used a newer computer causing this. And the fix was in the tune. But nothing about a newer sending unit.
Is there an easy fix for this?
Thanks.
Old 05-21-2015, 05:46 AM
Ollie8974's Avatar
Switch the two purple wires.
Old 05-21-2015, 10:58 AM
cchvyd28's Avatar
the purple wires back at the pump?
Old 05-22-2015, 12:14 PM
Ollie8974's Avatar
Yes. The plug in the fuel pump module
Old 05-26-2015, 07:24 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Switching the wires does nothing. It is not polarity sensitive.
If he installed a 99 sensor, it rotates the opposite way of a 98, so it should read backwards.
Old 06-11-2015, 01:07 PM
camarozz383's Avatar
Default same trouble
mine reads wrong to, I installed a racetronix fuel pump and auto meter gauge, full is empty, anything I can
Old 06-14-2015, 05:27 AM
stevieturbo's Avatar
No idea if there is anything similar in the US.
But this will allow you to change any resistance scaling...to any that you need
https://www.spiyda.com/magento/index...izard-mk2.html
Quick Reply: backwards gauge
