Fuel Leaks Out During Filling Up / Racetronix Fuel Pump Problems
Long story short, i installed a racetronix fuel pump and hotwire kit. The hotwire kit keeps (AND IS STILL) blowing the fuse which resulted in me rechecking/reconfiguring the location of the hotwire.
This is where i grounded the hotwire kit.
I now believe i accidentally pulled on my gas tank vent tube causing it to leak when filling up at the gas station. Or maybe something to do with the EVAP? I dont know..
If anyone knows how to go about fixing both of these problems without dropping the gas tank, i would greatly appreciate it! (I already cut a trap door for the fuel pump)
Thank you.
Thank you.
I once had an issue with a fuel leak on the tank after doing a fuel pump, only after filling up. It turned out that big rubber seal on top of the tank that seals the whole assembly wasn't seated correctly.
