fuel pump wont stop running
Old 09-06-2015, 06:57 PM
jlay's Avatar
Default fuel pump wont stop running
What would cause my fuel pump to stay running in a 2006 LS2 GTO. Fuel Pump relay has ~9 volts. If I turn the switch to acc it will prime like normal but not stop. The relay is not sticking. Motor does not have spark at the plugs. Any thoughts?
Old 09-08-2015, 01:39 PM
stevieturbo's Avatar
9v where ?
If you are 100% sure the relay itself is not at fault, dodgy earths or wiring can sometimes cause strange things to happen.
Do the coils have 12v at the relevant wire ? Is the ecu even going live at key on ?
And what happened prior to these faults appearing ?
Old 09-08-2015, 02:25 PM
jlay's Avatar
9 volts at the trigger wire from the ECM on the relay. Have battery voltage going to ECM when key is in on position and while cranking.
I think it may be from a ground issue I had possibly frying the ECM.
Quick Reply: fuel pump wont stop running
