What psi hobbs switch to use
Old 10-19-2015, 08:34 PM
autoaddictions's Avatar
Default What psi hobbs switch to use
Im finishing up a 6.2 turbo set up. I have a twin 360lph in tank fuel pump set up. Second pump turning on with a hobbs switch. Not sure what psi to activate!! I was thinking 4 psi!! What do you use???
Old 10-21-2015, 11:42 AM
jmm98LS1's Avatar
I use a 2psi switch on my second pump. So long as your main pump can handle the power you make on 4psi, then that would work fine too.
Quick Reply: What psi hobbs switch to use
