aftermarket fpr install
Old 01-15-2016, 05:23 AM
dt23400's Avatar
Question aftermarket fpr install
Hey guys, Im in the works of building a boosted 5.3 . Going to be running dual pumps. not decided on 255s or 450s yet. But my question is since ill be running a stock ls1 fuel rail, ill order an fpr that has a built in return line. My question is where do i hook that return line up at? is there a place in the hat to connect to? also do i need to pull the factory fpr out of the hat? Cant find a whole lot of info on it.
Thanks
Old 01-15-2016, 07:14 PM
dt23400's Avatar
No body?
Old 01-15-2016, 08:38 PM
Majestic9C1's Avatar
you need to remove the stock unit in the tank
Old 01-15-2016, 10:08 PM
dt23400's Avatar
and then what? run a return line from the regulator to the hat? is there a connection there?
Old 01-15-2016, 10:52 PM
Use your Evap line as your return line and just vent the Evap line from the tank to atmosphere
Old 01-15-2016, 11:07 PM
dt23400's Avatar
thank you very much for that diagram. i havent ripped into the fuel system yet so i was kinda blind on that one. Thanks for clearing it up for me. For some reason i couldnt find much info on how to do it.
Quick Reply: aftermarket fpr install
