My cheap fuel tank baffle/anti-slosh idea
Old 04-19-2016, 05:11 PM
roastin240's Avatar
Default My cheap fuel tank baffle/anti-slosh idea
I really really do not want to cut my stock tank in half to build baffles inside. The access hole for my dual in tank pumps is only 4 inch. My tank is 20 gallons.
I ran the numbers quick, and if I throw ~108 stainless steel scrubber ***** (you know the ones you can scrub dishes with), it will fill the entire inside of the tank and only add ~12 lbs and displace ~0.2 gallons.
Discuss. Thanks
Old 04-20-2016, 06:45 AM
LT1PWRD's Avatar
Discuss. Thanks
My solution
Old 04-20-2016, 09:32 PM
NemeSS's Avatar
Old 04-22-2016, 06:48 AM
LT1PWRD's Avatar
Originally Posted by NemeSS
Whats so hard to understand?
Old 04-22-2016, 07:11 AM
Old Geezer's Avatar
Talking What i'm..
wondering, too.
Old 04-22-2016, 09:00 AM
roastin240's Avatar
I considered an in tank Walbro under no pressure feeding a surge tank, and then my high pressure pumps from that...that would be a straight forward solution, but I do not want to run a surge tank.
Anyone else?
Old 04-22-2016, 10:00 AM
INSANEREINDEER's Avatar
Curious as to why you don't want to run a surge?
I did nothing to my Z32 as VERY few people have had issues with the car and it was only when make a hard left turn with less than 1/4 a tank.
I don't know of any options but I don't think fill the tank with scrubber ***** is the best idea. Nor do I think it would actually help all that much.
Old 04-22-2016, 10:17 AM
roastin240's Avatar
I decided to keep the stock plastic can thats inside the fuel tank and cut some of the baffles out of the inside of it. It holds about 1 gallon. I drilled some holes on the front of it so when I am pulling under boost, the fuel will be caught by that back wall and help feed the dual pumps.
Quick Reply: My cheap fuel tank baffle/anti-slosh idea
