can I have fuel injectors resized?
Having a hard time finding 42lb injectors that will plug into my stock harness 08 Trailblazer SS. Can the stock injectors be resized to 42lb? thanks
injectors
Believe me...I'm trying to find a direct replacement Problem is I either have to add an extension or change the connectors. I need 38-40lb injectors @58lbs pressure for 08 TBSS with EV6 (UScar) connectors. Stock ones aren't big enough. Ordered a set from Summit but sent them back, they weren't flex fuel and had wrong connectors, not that flex fuel is important to me.
