New FPR. Where is the other regulator?
Swapped to a Aeromotive 13129 and new rails. After junking the new rails because they leaked so bad, I put the new reg on the end of the factory fuel rail. I've made several adjustments and hasn't changed AFR even at idle. So, when I swapped to the dual pumps in my tank, I can't remember if there was a factory fuel regulator in there or noT. Is the factory regulator in the factory rail on a 98?
Its in the tank. This thread has a good pic of it.
https://ls1tech.com/forums/fueling-i...ost-fixed.html
