Boost referencing the stock 99+ F-body regulator on the bucket
It appears that the regulator in the f bodys is the same one they use on the truck rails. Is there any reason why you couldn't reference off of the manifold with the stocker instead of buying aftermarket?
**Boosted application***
You have 2 regulators, one of the fuel rail (if stock) and 1 in the bucket. I run an aeromotive boost referenced fpr on my stock setup. I gutted the 2 regulators in order to achieve the 40 psi base pressure of the SD 80lb injectors. If you're running bigger injectors you will need to be able to adjust the fuel pressure for the injector based from manufactures recommendations. Good luck
