Changing Race fuel? retune? or safe?
Old 11-16-2016, 07:40 PM
BFF Larry's Avatar
Default Changing Race fuel? retune? or safe?
i have a 416ci Ls3
-13.5:1 CR
-Hp Holley EFi V2
-active Knock sensors
originally tuned on F&L 113 octane
F&L SP-3 113 octane
PROPERTIES:
Research Octane Number: 118
Motor Octane Number: 109
Anti-Knock Index, (R+M)/2: 113.5
Specific Gravity at 60/60 /F: 0.725
Reid Vapor Pressure at 100 /F, psia: 6.0
Distillation Range at 760mmHg, /F (Initial Boiling Point: 93) (End Point: 264)
Oxygen, Vol. %: 2.7
Color: Light Green
Since i cant get this fuel locally, besides ordering it in to the shop.
I can get VP 114 octane
SPECIFICATION SHEET FOR C-14
(Typical Values) Specific Gravity: .696 @ 60°F
Lead: Yes
Color: Yellow
Motor Octane: 114
Reid Vapor Pressure: 5.16
Oxidation Stability (min.) 1440+
Distillation:
10% evap @ 168.1°F
50% evap @ 210.0°F
90% evap @ 217.2°F
E.P. @ 240.7°F
Production: Elmendorf, Texas USA
Availability: Sealed Drums
Rev: 07/00
or
Sunoco 114 octane
Sunoco® HCR™ Plus
Color Orange
Octane (R+M)/2 114
Research Octane 118
Motor Octane 110
Specific Gravity 0.736
Weight (lbs/gallon) 6.1
Reid Vapor Pressure 5.8
10% Evaporation 170
50% Evaporation 217
90% Evaporation 228
Stoichiometric Air/Fuel Ratio 14.8
Oxygen (weight%) 0
Ethanol (volume%) 0
HC Ratio 1.99
Lower Heating Value (Btu/Gallon) 113700
Lower Heating Value (Btu/Pound) 18600
Dielectric Constant 0.3
Leaded Yes
I know the F&L 113 fuel contains 2.7% oxygen
but could switching to another fuel cause any damage?
or should i get a retune?
Old 11-17-2016, 08:49 AM
a05c's Avatar
Oxigenated fuel will make more power than a typical leaded fuel. You'll also need to increase overall fuel to compensate.
Might as well retune it, bigger question is; if you switch fuel.. are you going to stay on that same fuel. Switching fuels all the time just will add to headache when it comes to tuning.
Quick Reply: Changing Race fuel? retune? or safe?
