Cant put gas in my car
Hi all something is up with something. I dont know wtf is going on. Today i pull into the gas station to fill up and my car will not allow me to put ANY fuel in. I tried atr 2 different stations, and the same result. Could something be impeding the gas flow to fill my tank? Anyone else have this problem? ITs so strange! Please i need some opinions. I made it home, but im on empty! Thanks in advance
1st pull the inner wheel well cover off and look at the fill line and make sure it is not kinked or damaged. I believe ther is a small type of one way check valve at the bottom of the filler neck where it meets the tank. (what year is this) I am refering to a plastic tank. 99and up??? There might be somethng wrong with this???? I have a spare plastic tank let me look, send me a pm if I forget to back to you.
Chris
Chris
Ok i stuck a coat hanger in there, and fuel ******* squirted out everywhere.... very heavy pressure. I let it bleed itself. Can you tell me more about this checkvalve? Maybe the pressure from the fuel fumes had it shut and wouldnt allow fuel in the tank?
Originally Posted by AW794
No i dont, my buddy has a scanner ima borrow tomorrow
Ya sounds like a Venting problem... Too much pressure.. There's a white venting valve on the driver side of the car that attaches to the body of the car. This leads to the tank and is a 1 way venting valve. This might be plugged up.. You can lift up the rear of the car and check it out...
Good luck
Clint
Good luck
Clint
