Speed Inc. Fuel Rail fitting size?
Old 09-05-2005, 10:37 PM
Elite_Hot_Rod's Avatar
Default Speed Inc. Fuel Rail fitting size?
I bought a set of used Speed inc. Fuel rails and I need an AN6 male fitting to connect my fuel feed line to the rail. My question is what size is the male portion of the fitting that screws into the rail? TIA
Old 09-05-2005, 10:55 PM
Brandon Boomhauer's Avatar
3/8npt
you're welcome mark
Old 09-05-2005, 11:32 PM
Are you 100% sure about that Brandon? The fitting that came out of the rail is an AN816D-10 which measures .560" across the threads and has a bore diameter of .479 on the rail side of the fitting which is closer to 7/16 than 3/8. I think I need an AN 816-6D fitting.
Originally Posted by Brandon
3/8npt
you're welcome mark
Old 09-06-2005, 12:47 AM
direct from their site.
Speed Inc
High Flow Fuel Rails
We have been manufacturing high flow LS1 fuel rails for over 3 years now, helping to push the limits of LS1 fuel systems. The rails can be used with our install kit and the factory feed line or with our full race fuel systems. Available in Silver, Red, Blue, and Black they are also a quality show piece! Each end is threaded to accept 3/8’s NPT.
Old 09-06-2005, 07:44 AM
V6 Bird's Avatar
