what injector size should i get???
I'm getting ready to install a MS3 and PRC heads, 3800 stall, 4.10 and other bolt-ons plus I run a 150 shot of nitrous . Can someone tell me what injector size to get???? I have already upgraded the fuel pump to a Walbro 255.
Thanks
Thanks
I got a set of Delphi/Lucas 42# injectors from Thunder Racing and they are great. No problems tuning for them, idle is nice and I get 28 mpg all highway. I am at 58% duty cycle at 6400 Rpms, plenty of room for growth, for that 4" stroke...
Coal Mining Director
Bolt ons, cam and heads will be close to getting by on stock 1998 injectors. You could run it on a dyno with a wideband and see the a/f ratio. If you want to change and do a new tune, I'm a believer in the 42lb svo's. Idle great, easy to tune and will give you a lot of room to add hp later.
