i have 60lb i need 32lb injectors????
Old 03-21-2006, 12:37 AM
rudyzturbota's Avatar
Default i have 60lb i need 32lb injectors????
i just found out that in injectors i have in my car are 60lbs, which are way it big is what jason was telling me over at extreme. he is still trying to get them to program, but i might have to get some 32lb injectors, or something smaller then 60lb, does anyone have some injectors that will help me, or have any suggestion what i should do? thanks rudy
Old 03-21-2006, 12:53 AM
KLLVTEC's Avatar
why would you need smaller injectors ? whats wrong with 60s on a turbo car ?
Old 03-21-2006, 01:03 AM
rod442's Avatar
exactly, I plan to upgrade to 60's when my new motor goes in.
they can be a touch trickier to tune at idle Ive been told, but not impossible.
and if you do decide to go smaller, I wouldn't go smaller than 42's.
Old 03-21-2006, 01:13 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
told ya
Old 03-21-2006, 01:21 AM
DeltaT's Avatar
My suggestion would be to find another tuner after advice like that.
I'm running 72's and they tuned with no more problems than the 50's.
Jim
Old 03-21-2006, 04:48 AM
EPP
EPP's Avatar
With any forced induction LS engine, you would not want to run something as small as a 32lb injector? Are you sure you don't mean a 42lb injector? In any case, there is no reason not to run the 60lb injectors that you have, and they are normally quite easy to tune with. 42lb injectors can be close to being maxed out quite easily, stick with the 60's. Bob
Old 03-21-2006, 06:50 AM
ninobrn99's Avatar
With the wealth of info on how to tune IFR's we have in the tuning forum, how can he not be able to tune them? Its not hard at all to tune them. I agree with everyone else that you should stick with the 60's and not even think about 32# injectors.
Old 03-21-2006, 11:16 AM
well he told it would be no problem tuning other 60lb injector, but the one that are on there are pithon vinom injectors and is have a hard time finding any info about them. does anyone have these or know about these type of injectors?
Old 03-21-2006, 11:24 AM
also the motor is mostly stock with the sts setup, so isnt it just to much fuel that i will never use.
Old 03-21-2006, 11:28 AM
ninobrn99's Avatar
call them and ask what they're flowed at and what the fuel rail pressue they use. could be and more than likely will be different than our 58psi since they're ford injectors. http://www.python-injection.com/nf/html/contactUs.cfm
Old 03-21-2006, 11:35 AM
i have so has the guy thats working on it and the same stupid woman has answer, she has no clue what it is and just gives me the run around. he is going to keep trying to get tune, and let me know what he comes up with
Old 03-21-2006, 11:41 AM
ninobrn99's Avatar
so the people there dont know?
Old 03-21-2006, 11:45 AM
she would not know, and direct me to someone else, and then that person would just not answer. its hard to tune injectors if u have no info about them
Old 03-21-2006, 11:52 AM
ninobrn99's Avatar
Just got off the phone with them and they flow them at 40-42 psi. With our fuel pressure, they'd be more like 70# hope that helps./
Old 03-21-2006, 12:54 PM
i just got off the phone with my guy, he said its the fact that im only going to be runing 7lbs of boost and its overkill for my car, so im just going to trade for some svo 43's. which should work perfect.
Old 03-21-2006, 02:00 PM
DeltaT's Avatar
You got a lot of similar, tried-and-true advice here to be ignoring it...
J
Old 03-22-2006, 01:11 AM
not sure i understand what u just said
Old 03-22-2006, 02:36 AM
flyin red TA's Avatar
He said you're ignoring everyone that says to stick with the 60#ers.
I would listen to these guys that have been there first...but it's your car.
Old 03-22-2006, 03:38 AM
i suggest find as much info on them and then find a different tuner. there's no reason to go to 42's boost is addicting and you'll want more once you get bored with 7lbs.
Old 03-22-2006, 04:26 AM
EPP
EPP's Avatar
Question
I agree, you may not fully need the 60lb injectors with your current combination, but most of us are never satisfied, meaning you may end up buying the 60's in the future when you upgrade your combination. Bob
