Which BAP are you guys using??
There is the MSD BAP from thunder for 289. Or there is the Kenne Bell BAP. Which would I need the 20amp version?? If so which are you guys using for your setups?? Dont know if I will actually need one or not but its better to have to much fuel then not enough. Any info is appreciated.
My KB BAP is mounted in the trunk/backseat support. Just find the power wire going to the fuel pump and splice in the BAP per the instructions. As mine is somewhat difficult to get to, I removed the fuse and went with a circuit breaker instead.
You'll also need to decide whether you want the controller in the cabin or not. I left mine in the trunk set to about 16DCV.
Its a fairly easy install, have fun.
