Search not working, 98 Fuel Pump "?"
1 Post
Hey guys,
I'm bout to purchase a Walbro intank pump for my setup, however the "New Direct Fit" shows 99+, does anyone know if this is a typo, or why it wont work on a 98? I am doing a LS1 swap into my LT1, so I don't see why I couldn't use it in my current pump, I'm just raising the pressure to the LS1 desired spec of 58 over the LT1 of like 43 I believe....Thanks!!
Also I know the "Hot Wire" kit is desired for people making a decent amount of power, but does it have an advantage on a stock motor, with a few bolt-ons?
LS1TECH Sponsor
The LT1 kit, the '98 kit & the '99up kits should use 3 different configurations. All 3 tanks are different as well. If using a separate fuel pressure regulator, you can upgrade to a new LT1 intank setup. It will work well with the LS1 as long as you have a way to properly control the fuel pressure.
1 Post
So N8, since my car is an LT1 car can I just put the 99+ Direct Fit Walbro pump, and hotwire kit in it, or do I need to do the LT1 pump? Eitherway from what we talked I drew it out, and can plumb fuel line from the back to the front getting a regulator using the 98 rails I have, or FAST for $500 braided up to the rail....
If you can help me out on this pump thing, it would be APPRECIATED as all the other help you have been is...
1 Post
Well the reson why I am confused is, why does this pump say it works 85-02?
Looks the same, as the others really...
http://cgi.ebay.com/ebaymotors/ws/eB...0307&rd=1&rd=1
